Engine side Bulkhead Connector is stuck - any ideas?
Old 04-26-2015, 07:55 PM
williestargell's Avatar
1983 Dodge Rampage 2.2
Removed the 10mm bolt on the engine side of the 40-way bulkhead connector. Usually these pop right out with no problems, no resistance. This one is stuck like hell. I've been at it for hours with a pry bar, screwdriver, wd-40, yanking & pulling and it's gave about 1/8"... though i think i'm over estimating.
What gives? I have a spare engine-side bulkhead connector so I'm OK with this one getting destroyed. There's nothing in there as far as I can tell that isn't plastic-on-plastic. Except *maybe* the lock washer and t-nut got corroded together? that's not very much surface area and the bolt wasn't corroded...
Old 04-27-2015, 04:33 PM
You may have some melted together.
74Runneer
01-15-2015 05:43 AM
TwistedWrenches
09-13-2009 05:00 AM
scotts74birds
09-07-2009 12:12 PM
cjperry81
03-30-2009 12:35 PM
alaskagirl
07-31-2008 11:45 PM
Quick Reply: Engine side Bulkhead Connector is stuck - any ideas?
