Mopar gods please help with electornic distributor......
Old 07-13-2013, 02:34 PM
Mr442's Avatar
Dear mopar experts,
I am working on a 1970 plymouth barracuda with a 318 2 Bbl. it had a points style ignition. I bought a electronic distributor from evil bay and it had no instructions. It is on evil bay under dcm performance and I was wondering if anyone knew how to wire it?
It has 2 wires a red and a black coming out of the distributor and claims it does not require anything except a upgraded coil.
Any help is appreciated, I do have a MSD blaster coil to use.
Thanks in advance.
Old 07-13-2013, 02:44 PM
This and others are easy to find:
http://www.mymopar.com/downloads/elecignconv.pdf
Old 07-13-2013, 03:01 PM
Mr442's Avatar
Follow up
I just have a electronic ignition distributor, and a MSD coil.
No kit , no instructions?
Do I still need to buy a kit, and would it have everything but the distributor?
Dazed and confused.
Old 07-13-2013, 04:40 PM
moe7404's Avatar
you need a orange or blue box. i think the stock 1970 coil will work , but ask the real experts. the box and a wiring harness from chrysler is all you need. here is an easy test for the distributor by its self. get an analog VOM. set it to the lowest ACV setting. put the VOM wires in the distributor wires. then spin the dist shaft. if the VOM needle moves just a little the dist is good.
Old 07-13-2013, 05:11 PM
Wouldn't let me copy and paste (PDF) Some great info on setting the timing
Old 07-13-2013, 06:07 PM
Sounds like it is one of the ready to run units your talking about?.....
If that is the case. You just replace the ignition coil and then hook the dist. wires,(Red to + and the Black to -) and your set to run after installing the unit.
If it is the ProComp one Or the ready to run one....Yes its that easy !!!!!!
http://www.ebay.com/itm/Small-Block-...cedf44&vxp=mtr
Old 07-13-2013, 06:27 PM
A description or picture of the unit would help, "Electronic Distributor" covers alot of ground.
Old 07-14-2013, 08:17 AM
Mr442's Avatar
Resolved distributor wiring
Well, I remembered pertronix has a kit to convert from points to electronic and I went to their website and there was my wiring diagram.
Thanks for all your input, duh on my part, how would we live without the World Wide Web. It was that easy....thanks
Old 07-14-2013, 09:25 PM
Let us all know how and if you like it when it's done and running......
dreyerot
12-02-2013 12:48 AM
70Coronet
05-07-2012 06:48 AM
DUST360
10-11-2009 09:54 AM
valleyofthesuns
09-24-2008 09:56 AM
390AMX
06-11-2008 07:28 PM
Quick Reply: Mopar gods please help with electornic distributor......
