Please ID these wires wires!!!
Old 06-17-2012, 02:27 PM
Macjeep's Avatar
In need of some help I have a 1998 jeep 5.9 and I just rebuilt the motor but in the move some cables lost third labels and I can't for the heck of me figure out where they go here they are
It comes out down by where the ele fan plug comes out
Comes out of the hardness on the passenger side by the injector plugs I thought it was for the ax pipe but does not fit
Looks like a fuse box wire but there's already on there? Are they both Spose to be there?
I have no idea about this one... Please help please
Old 06-17-2012, 04:23 PM
PK1
PK1's Avatar
Post a pic.
Old 06-17-2012, 05:22 PM
Macjeep's Avatar
Huh dumb I thought I did
Did this photo work? It's by the electric fan
http://pbckt.com/pt.upZROy
Old 06-17-2012, 07:34 PM
Macjeep's Avatar
woot got it fixed
Old 06-18-2012, 03:14 AM
PK1
PK1's Avatar
First one should be Idle Air Control behind TB on the rear most upper sensor. Only other sensor that uses that type terminal is AC junction but its on the other side. And secondary AC E fan power.
Old 06-19-2012, 09:46 AM
Macjeep's Avatar
Bump
Old 06-19-2012, 12:01 PM
PK1
PK1's Avatar
1. IAC control on the rear of the TB or the aux E fan which I don't see attached in your picture.
2. IAT sensor in the manifold "Intake Air Temp" Only other thing it could be is washer tank volume plug. But the colors changed to black in other models.
3. Power
4. What are the the color of the wires? With the keyed lip it, look to see if you have a ground strap on rear of passenger side cylinder head. Or behind the coil bracket under the alternator.
4.
3. Power
Dartingtraffic
03-07-2012 04:58 PM
DUST360
10-11-2009 09:54 AM
Morrigan_Aria
08-06-2009 07:04 PM
06-10-2009 01:53 AM
rabys
03-22-2008 11:37 AM
Quick Reply: Please ID these wires wires!!!
