Rear light question
Old 12-18-2016, 01:19 PM
1970ccc's Avatar
Rear light question
My back up lights only work with the other lights off. In other words, headlights and or parking lights on, no backup lights. Is this a switch issue? If so, which one?
Old 12-18-2016, 02:21 PM
Do you have a good enough ground at tail lights?
Old 12-18-2016, 02:28 PM
1970ccc's Avatar
I have enough that the brake lights, turn signals, and side markers work. But sometimes the left rear brake light goes out when in reverse.
Old 12-18-2016, 03:05 PM
fivepoint's Avatar
As a general rule, if something electrical is acting goofy, look for a bad ground. Clean all connections and grounding points. Make sure all of the bulbs and sockets are clean and corrosion free.
Old 12-18-2016, 04:20 PM
There you go.
Old 12-18-2016, 06:15 PM
Make sure your using the correct bulb also.. Good Grounds is a must....
70plumchallenger
08-11-2015 08:26 AM
mr.300
02-12-2012 11:33 AM
fishpwr
02-28-2011 11:09 AM
65AzBel
11-13-2008 03:05 PM
roadrunnerrelic
10-17-2008 12:23 PM
Quick Reply: Rear light question
