tach test
Old 11-01-2012, 05:12 AM
castillo70's Avatar
tach test
is there any way to test a tach without a motor/dist. i have the dash out and would like to test it somehow. or where could i send it off too?
Old 11-01-2012, 10:39 AM
Sure, if you have an amplifier with conventional analog outputs ("plain old speakers")
Go to Radio Shack and buy this:
http://www.radioshack.com/product/in...30#tabsetBasic
Pick up a 2000 ohm (2K) resistor, and whatever cables you need to (cut and splice) to hook the speaker (low impedance) side of the transformer to your amplifier output on one speaker.
Wire the 2K resistor across the high impedance terminals. This protects the thing from transients. Wire your tach to 12V as designed, and ground one lead of the high impedance winding, and hook the other to your tach trigger lead.
Google the internet for musical tones, and convert that to what your tach would read, IE 440hz is 6600RPM
Here, read away. I checked the tach in my 67 here
http://www.forabodiesonly.com/mopar/....php?p=1573256
fredcole
02-07-2010 07:30 AM
schmeel
02-03-2010 11:34 AM
cudaneil
05-16-2009 05:32 PM
68 Sat
03-16-2009 08:13 AM
moparbob
09-02-2008 03:46 PM
Quick Reply: tach test
