Voltage regulator rewiring
Old 10-27-2014, 10:20 AM
josehf34's Avatar
Hi!
A few days ago my 1974 fury blew its stock mopar voltage regulator on the electric shop they replace the bad regulator with one of these but three days ago I noticed that the battery was receiveng a lot more voltage (17.3V @ 2500 RPM) I think the new regulator has died so I bought a new mopar regulator.
Now the problem is that I don't know how the mopar regulator must be wired. The replacement voltage regulator has 4 terminals (IASF) and the mopar just two and according to the schematics one of these is the black big wire from the alternator connector. In the electrical shop the guy just left the alternator FLD terminal unplugged but the alternator has the FLD terminal and another terminal. Which one must be plugged to the regulator?
Old 10-27-2014, 12:12 PM
4 pins ? Why not get the correct regulator Less than $20 at auto zone Unless they cut the plug off ? it should just plug in....
Old 10-27-2014, 02:01 PM
moe7404's Avatar
really the stock volt reg has 3 connections. 2 are on the face of the case with a plastic holder. the 3 rd connection is the ground throu the case, to the car chasie . so if the the volt reg is not grounded good the system will not work right. same thing with the electronic ignition system. here is some pics, of what i think is the one you need.
http://www.ebay.ca/itm/Voltage-Regul...-/231120172504
Old 10-27-2014, 04:08 PM
I agree.... Make sure you have the ground strap from the fire wall and bolted to the back of the cylinder head. or at least some-wear....
Old 10-27-2014, 08:47 PM
josehf34's Avatar
The regulator died on a sunday afternoon and that regulator was all that was available
I've two ground wires, one from the driver cylinder head to the battery negative and other from the passenger cylinder head direct to the car body.
Will this be enough?
Old 10-27-2014, 08:59 PM
Well you got the grounds covered..
Old 10-28-2014, 12:25 PM
moe7404's Avatar
try this URL. should be a good pic
https://www.google.com/search?q=chry...or+wiring+pics
98 SNAKE EATER
04-15-2013 01:47 PM
dodgenut7
05-01-2010 06:36 AM
scott2683
04-18-2010 07:57 PM
440Challenger
08-13-2008 03:04 AM
71 GTX
02-20-2008 08:07 AM
Quick Reply: Voltage regulator rewiring
