Can door skins be reused ???????????
Old 04-11-2015, 09:18 PM
motasupra's Avatar
Ok just got two new doors for our car but one had bondo under the paint. can I put the door skin from my current door on the other one? one had a bad frame and the other has a bad skin.
Old 04-12-2015, 05:57 AM
I had to think about this for awhile, I suppose you could cut the spot welds on the skins then unfold the skin from the frame then remove. Then reinstall on good frames that have been cleaned up.
Why do you need to change the doors?
Old 04-12-2015, 11:44 AM
motasupra's Avatar
when I was looking at them it looks like the door hangs on the top of the frame and then has all spot welds on the sides and bottom. I will try to put up some pics. So the main question is if i can remove the one with out trashing the skin. there was hardly any rust on the doors just surface that I put the rust gel on after some wire brushing with the grinder and then using the rust primer spray take that rust. no real pitting or bubbling.
Old 04-17-2015, 12:48 PM
I would check with AMD Metals. May be easier to just buy a skin if it is available. I would bet you ruin it Trying to remove it ? maybe not ?
Old 04-17-2015, 05:15 PM
I have to ask why do you need to replace the doors/skins? lets see some pictures. Have the doors have been gutted for racing and skinned with aluminum, then why not replace the center of the door frame that holds the window mechanism? Leave most of the door intact, as is.
Old 12-22-2017, 06:05 PM
Blackbird's Avatar
And if AMD doesnt have them a good sheetmetal fabricator could make new skins
rcknrolfender79
03-13-2013 10:50 PM
SaltyDogsrfr
06-06-2011 05:43 AM
Idrivemopar
10-23-2010 08:58 PM
67 Fury
01-07-2010 10:29 PM
jeffaary
07-25-2008 09:50 PM
Quick Reply: Can door skins be reused ???????????
