lean burn delete
Old 02-25-2015, 08:07 AM
evrae205's Avatar
lean burn delete
i've got an 85 fifth avenue with my lean burn acting up was looking for a how-to link or advice on an inexpensive alternative.
car is my daily driver and i hate to give up and find something else since parts are generally quite cheap and the engine is in overall good running condition.
search button has yielded a few threads but no definitive how to's with a parts list.
Old 02-25-2015, 10:09 AM
moe7404's Avatar
i had an 84 ply gran fury. it had a cracked intake. made the plugs look like they have been in the exhaust. swaped the intake. and put the standard electronic ignition system. things to look for. 1. check the back edge of the intake that it clears the distributor before you bolt it on. 2. if going to a 4 bbl get the right cable, bracket, linkage. 2 bbl has diff parts than 4bbl. DONT cobble it up. use the right parts even down to the right washer on the carb pull pin.. 3. no matter which intake DO use anit-seize compound and teflon tape on the water hole threads.. and check heater hose sizes. 4. if going to an aluminum dont put a square bore carb on a spread bore intake with out the right steel plate from edelbrock. 5 do NOT run hose for fuel line. make steel lines like the factory did. 6. and get two new ignition ballast resistors and put in the glove box. on the next NO start just swap it out.
Old 02-26-2015, 05:40 AM
Gorts 5th's Avatar
Smile
What is the acting up symptoms ?
how many miles on ur 5th
Im assuming yoi did all the standard checks
plugs
wires
cap & rotor
fuel filter
pcv valve
vacume leaks
loose carb
if u do the swap moes advice is good
You will nd a new distibuter with vacume advance ...
and a two bbl carb ..its been so long I forget the brand name I beleve a rochester ..from some mopar 318 with out the lean burn system.
Old 04-15-2015, 08:04 AM
evrae205's Avatar
sorry late reply
alright i caved and bought a reman computer and many of the symptoms improved.
rough idle still exists and stalling out at stops. however the backfiring completely disappeared. very difficult hard stops has improved as well.
i've checked for vac leaks with a smoke machine and it came back good.
replaced ignition coil,plugs,wires and air filter during a regular tune-up and although needed did not solve the symptoms just minor improvement on fuel economy.
Haven't moved to my cap and rotor or distributor pick-up yet
current symptoms are rough idle stalling when braking or throttling on occasion, intermittent flooding.
I hate to dig into the carb without eliminating everything else.
Old 04-15-2015, 08:08 AM
evrae205's Avatar
Cool
plugs
wires
cap & rotor
fuel filter
pcv valve
vacume leaks
loose carb
gonna replace cap,rotor,pcv valve and fuel filter this weekend while i'm doing my u-joints and another oil change. I really don't want to dig into the carb by myself i know very little about them.
anything i cant hook my solus up to i'll need help with.
Old 03-09-2023, 02:07 PM
oldman's Avatar
Is your EGR valve still connected? If it is that could be your problem.
MrOldart2U
05-11-2012 11:36 PM
rickswanson
18
04-09-2012 08:53 AM
mirada82
02-24-2012 01:49 PM
Commando
11-21-2007 05:02 AM
wknet6
10-21-2006 09:55 AM
Quick Reply: lean burn delete
