A body hemi swap
Old 01-27-2019, 06:08 PM
montac's Avatar
A body hemi swap
I am in the process of swapping a late model hemi into my buddy's scamp. Episodes 1 and 2 are out with 3 on the way. It is exciting. Does anyone here have experience with steering setup or brake master cylinder placement? Thanks.
https://youtu.be/di38zTrzTPs
Old 01-28-2019, 02:15 PM
No experience but keep us posted with your progress.
Old 02-10-2019, 06:09 PM
montac's Avatar
Engine is in!
Lots of interferences but it is in. Next step is getting the transmission in!
https://youtu.be/YbdI9MgacH0
Old 02-10-2019, 07:22 PM
Looks as bad as putting a RB big block in, if I remember correctly the steering will move 3/4 of an inch but what I did was shorten the housing to just after the fire wall and then put a Borgensen joint in place on the rag joint. I used 2" under car headers so the steering was a pain.
Good luck with your progress it looks like fun! What are you going to use to run it, stock harness?
I was just thinking that if you turned the manifold around turbos could be fitted and it would save so much grief on the exhaust. Just a thought. 🙂
Old 02-11-2019, 11:41 AM
Going to be a tough fit for sure... Keep us posted and keep on chipping at it...
Old 02-11-2019, 12:03 PM
Here is something to read on the subject , I had to get Google crome out of my phone to post this what a pain, it has been stopping lately and today it would not let me use clipboard.
https://www.hotrod.com/?s=Gen+3+older+pu+swap
https://redirect.viglink.com/?format...-swap-guide%2F
Old 02-11-2019, 02:53 PM
montac's Avatar
Thanks for the insights! I do plan on running the stock harness. I have definitely considered the twin turbo approach. I will keep you guys updated. Thanks for reading and watching.
5thRider84
10-17-2019 10:09 AM
Stinky211
04-22-2019 12:05 PM
70 Dart Swinger
06-07-2012 03:06 AM
NMCA Jeff
shopHEMI.com NMCA's LATE MODEL HEMI SHOOTOUT - 5-7 JUNE 2009
02-25-2009 09:33 AM
bgreene30
11-20-2007 12:49 PM
Quick Reply: A body hemi swap
