Yet another exhaust manifold.
Old 12-01-2016, 12:59 PM
LeaningTowerOfPowr's Avatar
Hello
My Valiant has a crack in the exhaust manifold for the 3rd time in 6 years. I am going to replace it again soon. Im wondering which manifold I should choose as far as material. Ive seen a variety of metals available with an array of price ranges. Heck, I have even seen plastic. Anyway, what do yall think? Tired of replacing manifolds.
1970 Valiant, 3.7 Slant Six. Completely stock. 60k orig miles
Old 12-01-2016, 01:28 PM
That s odd???? Were is it cracking? Is it the same spot every time?
I will have to say. Here in SO-CAL.. I have not had any of those type problems..
Old 12-01-2016, 01:34 PM
Hey Racerhog
It seems to crack in different places every time. I was told once that its due to the block and manifold being of different materials and thus expanding and contracting at different rates. Plus living in Phoenix in extreme heat then going to the mountains where its much colder helps with the cracking. At any rate, it needs replacing again as my car is getting louder and louder.
Old 12-01-2016, 01:39 PM
The crack usually happens between the inlets in the manifold.
Old 12-01-2016, 01:42 PM
Are you using new or used manifolds?
Old 12-01-2016, 01:47 PM
I am using junkyard manifolds. I wanted to buy new this time and see if that would help. I was just concerned about what material to get.
Old 12-01-2016, 01:53 PM
This is a good one for the leaning tower of Bob /////////
Old 12-01-2016, 02:06 PM
Thanks Tom...lol
LTOP:... I agree with you on the temp change... Phoenix and a place like Prescott (PressKit) are and can be challenging when dealing with temperatures....
Most of the Cast Iron stuff your dealing with is more than seasoned to be up for using without having an issue! At least thats what I think.
Here is where I think you might be able to do some improvements....
Use the 5 minutes rule when starting the car, Let it warm up for 5 Minute.
And for shutting off the car, Let it Cool at idle for 5 minutes.
This will help the temperatures on both side of the heat cycle, cool down and warm up.
Know, I'm going on this info guessing that the tune up is all in good working adjustments. Not lean... Not rich... Not heavy in timing one way or the other.
Just food for thought. and something to try....
Just my 2 cents....
Iowan... What do you think?????
LeaningTowerOfPowr (12-01-2016)
Old 12-01-2016, 02:15 PM
DANGER DANGER
I think it's in the tune up!
Old 12-01-2016, 04:02 PM
Drag Pak's Avatar
I've seen v8's with this problem.
Might be a good idea to put a straight edge along the head and then along the manifold before assembly next time. Both may need surface grinding to true them up.
Old 12-03-2016, 01:09 AM
MAKE sure you are using the correct fasteners. They are designed to allow the manifold to move with expansion
Old 12-03-2016, 02:50 PM
I forget that not everyone would know to cut let alone check a used manifold prior to installation, it's automatic with me, but check a head that's good.
Old 01-18-2017, 08:01 AM
70newport's Avatar
If this is the 3rd manifold you have had crack I would be confident that Drag Pak is on the money with the head not being straight. any update on this though?
Im curious.
Old 01-19-2017, 05:28 PM
Just a additional thought, Make sure the exhaust pipe it supported and not just flapping in the wind
06-09-2018 07:28 AM
D'etroit
10-09-2009 07:39 PM
TwistedWrenches
03-07-2009 07:19 AM
polyspherical
02-01-2009 12:29 PM
nicolette
12-19-2007 12:13 PM
Quick Reply: Yet another exhaust manifold.
