406 MAGNUM (Small block) CRATE ENGINE 435 HORSEPOWER
Paid $9800+ shipping and is brand new!
Open to offers. NO LOWBALLERS!!
This 4.00" stroker engine generates a whopping 435 horsepower and 470 ft.-lbs. of torque, and will quickly make believers out of everyone. It features big valve Magnum R/T cylinder heads and stainless steel valves. Drop one in and let er rip. For maximum performance, Mopar recommends the use of a 750 cfm Holley carburetor (P4349228) and 1-7/8" exhaust headers.
Specifications:
Thermocycled Block Is Bored to +0.020" Oversize
4.020" Bore/4.00" Stroke
9.0:1 Compression Ratio
Big Valve Magnum R/T Cylinder Heads
Distinctive Mopar Cast Aluminum Valve Covers
2.02" Intake and 1.625" Exhaust Valves
Heavy-Duty Valve Springs
Hydraulic Roller Camshaft 288ฐ/292ฐ Advertised Duration (230ฐ/234ฐ Duration @ .050") 0.501"/0.513" Lift
Single Plane, M1ฎ 4-bbl Aluminum Intake Manifold
(Includes Bosses for MPI Conversion; Taller than Stock Check Hood Clearance)
Double Roller Timing Chain and Sprockets
8-quart Center Sump Street/Strip Oil Pan
Mopar Electronic Ignition Kit with Distributor
Heavy-Duty Engine Stand and Engine Crate
Does Not Include Accessory Brackets
Not for Use with A/C or for Factory MPI Installations
High Volume Oil Pump
Externally Balanced to Stock (Production) 19932003 360 Magnum Engine;
Specifications:
