87 d150
87 d150
Ok so I'm having a problem I'm hoping some one can help with. I pulled a 360 out of a b350 custom only problem I'm having is pilot bearing fitting into the crank. Trans is an a833, bearing fits the shaft just to thick for the crank. Did the vans have a different crank or something?
Not all cranks are drilled for a pilot bearing.
chlngr1970 (05-01-2021)
