Does anyone know what the ohm value is for the fuel sending unit
For a 1989 W250 w/360? I'm having a hell of a time finding the fuel module so I will probably R&R the whole thing. I was going to replace the sender unit in the tank, but I can't find anything, online or local. I guess I can clean it up and pray that it works. Does anyone know the ohm value for the sending unit for this year and model? Thanks!!!
Chrysler and ford use the same values,I know a few people who just used a ford sending unit and adapted it to fit. Here's a link that might help:http://www.fordification.com/tech/fu...ding-units.htm
good luck,john
good luck,john
good luck,john
good luck,john
Ohms/Resistance Popular Models
(Empty/Full)
0-90 Ohms _________________most GM cars, 1965-up
73-10 Ohms ________________pre-1989 Fords & most Chryslers
240-33.5 Ohms______________Industry standard, works on many popular cars
0-30 Ohms__________________most pre-1965 GM cars
16-158 Ohms________________most '89-up Fords
So should I assume a 240-33.5ohm for the 1989 w250 sending unit? Thanks!
Thanks!!! I am confused, on the chart:
(Empty/Full)
(Empty/Full)
john
trying to figure out specs for a 88 dodge d100. All the sending units are discontinued and im putting a fuel cell in the bed Of the truck with an inline fuel pump. Need to know fuel pressure for it and ohm specs if you have them sir
I heard somewhere that corrosion gets into the contacts and connectors and kills the signals to the dash. I’m just getting ready to TS my fuel sender issues and that’s where I intend to start. I’m taking the box off so I can get at everything for a 4 link mod anyway... might be a simple fix.
