i need help with 1986 d150 cam swap
Old 12-25-2013, 03:04 PM
spike1986's Avatar
so i currently have an edelbrock #3776 intake installed and edelbrock 1406 carb with electric choke and i am now installing a set of hooker super comp headers #5811 as well as a summit k-6900 cam and lifter set and my question is is it possible to do the cam swap without removing my 318/727 from my 1986 dodge d150 thanks
Old 12-25-2013, 03:54 PM
Myraman's Avatar
If you have enough room in front of the motor to tear things apart radiator,etc.. then being able to get to camshaft to pull straight out, then possible. Must be able to come straight out and then straight back in! But again depends how much room you have. As far as the lifters etc, if you can reach in there to get to everything, then great. If not it might be easier to pull it out. My couple of pennies.. Good luck!!
I'm pretty sure others will chime in. Great place of info!
Old 12-25-2013, 04:25 PM
Yes, lots of room.
Vantasia
08-02-2015 12:56 PM
Houston281
05-09-2012 08:08 AM
r130
02-06-2012 09:28 PM
dchamp
04-12-2009 09:32 AM
1982dodgeram
11-26-2008 02:27 AM
Quick Reply: i need help with 1986 d150 cam swap
