odom. does not work
That is weird. Usually the odometer works off of the speedometer. Is your speedo cable tight (the speedometer doesn't bounce around while driving)?
I'd take apart the original one and see what's up with it.
Sorry to chime in on an old post. I recently found this forum, and a 1990 D150 in excellent shape. Mine has the same problem. I reset the trip meter to zero after i did the first oil change and now it no longer works.
Have you found the problem to properly fix the issue?
Thanks
Thanks
I guess I'll try to find a replacement unit.
Thanks again.
Just for info, This is for fd http://www.ebay.com/itm/94-95-96-97-...fdeYZg&vxp=mtr
ef8340
12-17-2008 12:07 AM
