.060 Piston Recommendations?
Old Feb 20, 2010 | 08:52 AM
Slice's Avatar
I'm looking for a set of .060 pistons for a roughly 550 hp stock stoke 440. Most of what I've seen available is .055 overbore. Does anyone have a suggestion? Are Probe srs pistons any good?
Old Feb 20, 2010 | 10:56 AM
check out TRW
Old Feb 20, 2010 | 01:18 PM
John Van's Avatar
Slice, did you get the block bored out already? Did the machine shop sonic test the cylinder walls? Going .060 over is a lot and makes the cylinder walls pretty thin.There are special cements that can be used to partially full the water jackets,but is recommended for a race only engine.
Old Feb 20, 2010 | 06:43 PM
Slice's Avatar
Didn't bore it yet. Do you know what is acceptable and what part of the wall is in question?
Old Feb 21, 2010 | 07:05 AM
the 440 can be bored out .60
but, it then is less acceptable to power
Old Feb 21, 2010 | 11:59 AM
John Van's Avatar
Slice, 67GTX is right. Bring the block to a machine shop first. Have them clean the block and check for cracks first. Have them check the cylinders to see how much they need to be taken off the bore, I would go for only what is necessary. If too much is taken off the walls they can actually flex, causing a loss of piston ring sealing and therefore power loss. See what the machine shop says.
Old Feb 21, 2010 | 08:16 PM
Slice's Avatar
Sounds like a bad place to start. Think I'll use another block. I have a 78 block running in the car now. I think is .030 over. I liked having the car up and running while I worked on the other motor, but I guess I'll pull it and start fresh. Thanks for the valued opinions.
Old Feb 23, 2010 | 04:55 PM
keep us posted
Hotwheelz
May 19, 2009 10:27 AM
1 Bad Mirada
May 11, 2009 07:41 PM
bgreene30
Sep 1, 2008 01:40 PM
bgreene30
Nov 23, 2007 09:08 PM
bgreene30
Nov 17, 2007 10:39 PM
