1971 Charger S/E w rebuilt 383 and 727 Tranny
Old Sep 16, 2011 | 08:05 PM
minncharger's Avatar
This car has a Edelbrock 1406 and engine was running fine until I decided to take off the Dash to have it redone.
It then sat unused and was not started for a couple of years while I was deciding whether to take everything apart and start from ground up.
Just today I put new gas and turned it over.
It started but died within a few seconds.
The carb is getting gas and after pumping the gas pedal a few times while turning I flooded it. But still will not start and keep running.
The carb is prob 6 years old.
Should I try to take it apart and clean and/or rebuilt it or just spring for a new one?
Old Sep 17, 2011 | 07:27 AM
70newport's Avatar
im no expert but i would say cleaning it would be your best start and go from there especially seeing as it seems at least that your not in a huge hurry, but are you sure its ur carb? is it getting spark? check your sparkplugs?
Old Sep 17, 2011 | 12:35 PM
Let it sit overnight after spraying carb cleaner and turning it over.
This morning, starts like a champ.
Just hearing the sound of the twin exhausts was reward enough.
Amazing after sitting for a while it even holds idle.
I need to get back into finishing it now damn it!
Moparkid88
Apr 28, 2015 08:48 PM
dpmalibu
Jun 20, 2013 08:51 PM
JimmyEatsWorld
Jun 6, 2013 09:10 AM
69POLARA383
Jun 11, 2011 11:04 AM
Hotwheelz
May 19, 2009 10:27 AM
