1972Dodge Charger
Old Oct 14, 2008 | 11:24 AM
I got a carpet kit from summit racing for my D200 for a good price.
What are your plans for it? Once you can give us an idea about what you want to do with the car, we can tell you where to go and what to look for.
...and welcome to the board.
Old Oct 14, 2008 | 03:03 PM
i could always find what parts i need through summit
but whenever you order, always talk to someone
Old Oct 14, 2008 | 04:40 PM
challenger's Avatar
Thumbs up
just like 78 says there are tons of places we get our stuff from so all we need to know is what your looking for at the time and we will help you
Old Oct 15, 2008 | 07:21 AM
With summit you can't just type in what you have for a car and go that route. You will have to shop by motor, by car, and by department. There is plenty of knowledge here as well that can help you and guide you as to what to look for and where. Summit Racing a a good first place to look. Also do a search for mopar performance parts on google or something. You'll be suprised as to how many places there are out there.
For instance: Here is a header back exhaust that Summit Racing makes that is 3". It is designed for your car with a 318 though. I would imagine that a set of long tube headers will fit and exit in teh same spot on a 318 as they would with a 360 since its the same block and heads.
http://store.summitracing.com/partde...5&autoview=sku
Best thing That I would do is gather up as much info as posible for what parts are interchangable and go from there. I'm sure that a set of headers that is designed for your car with a 318 will fit your car with a 360.
If I'm wrong, then let me know.
Old Oct 15, 2008 | 08:23 AM
Commando's Avatar
That is a good point, I bought a set of headers from them for my 400 engine in my Cordoba for something like $90, but it didn't have my year on their site for that part. I bought them as it was an amazing deal, and open the box and there is a sheet with the applications in there and only about 1/4 of the apps were on their site.
So go with what you know, and look up by engine or car and find the interchangeability. I have been using them to find parts numbers to buy stuff at my friends shop, as he is cheaper then them (if not he can match some parts prices), but I have a New Yorker engine to put into the Cordoba, so I have a lot of fun finding things.
Old Oct 19, 2008 | 06:25 PM
you keeping it stock for the time being til you can save up for everything at once?
Old Oct 20, 2008 | 03:20 AM
rr69half6bbl's Avatar
welcome to the forum, nice looking project. The fuel line may be plugged in the tank, there is a sock that fits on the sending unit, and over time it falls apart, ither it collapses on itself plugging the line or it just falls into pcs. and plugs the line, the first thing to do is blow air back through the line from the front, then try the pump again and see if it primes. if not then id say drop the tank. take the sending unit out. Ive always used carter hi -po- fuel pumps from summit, they never quit , and dont leak.for an exh. tti has nice header applications, and they offer a full system to match. they re alittle more expensive, but, its worth the money.
Old Oct 20, 2008 | 12:42 PM
BuckNeccid's Avatar
Another thing you may want to look at is whether there is a hole in the fuel line anywhere. If there is, you'll be sucking air thru that hole and it won't draw the fuel from the tank. All the other advice is good as well. Priming the pimp... basically getting some fuel into the line or pump some way. It can be done, but I'm lucky to never have had to do it.
BuckNeccid
Jan 12, 2012 04:38 AM
olebrowndodge
Feb 10, 2011 03:28 PM
68lover
Apr 20, 2010 07:23 PM
DartConvertible
Oct 8, 2009 11:59 AM
