3:55 Gears vs Stock 3:23's
Old Jul 22, 2009 | 10:20 PM
mopar nate's Avatar
hey what part of chi you from like town wise
Old Jul 22, 2009 | 10:33 PM
Morrigan_Aria's Avatar
Hell kitten
You can get center sections from a light truck place! Tell them it's for an older Dodge truck, NOT a muscle car. You can find your casting numbers and give those to the parts guy...ensure you specify you want a Suregrip.
Unsure what the prices are currently, but I got mine for $125 a few years back.
Old Jul 23, 2009 | 07:30 AM
Polaradude's Avatar
Your safe..hahaha. Why are ya changing gear sets ? And yes the sure grip is Mopar and posi trac is Cheby.
Old Jul 23, 2009 | 08:31 AM
Hell kitten
Here ya go, from http://www.dippy.org/forum2/index.php?topic=78.0
It was easier to borrow this than to reinvent the wheel...er...differential..
How to Identify Sure-Grip And Gear Ratio
How To Identify A Sure Grip (Limited Slip) Differential
A limited slip differential provides better traction than an "open" type differential by automatically transferring power to the wheel that has the best contact with firm ground. Through the years, all of the major car manufacturers had their own names for the limited slip design - most notably General Motors' "Posi-Trac". The term "Posi" has now become a generic term for limited slip differentials, regardless of the make. Sure Grip is Chrysler's name for the limited slip differential. It was introduced as an option in 1958 with Chrysler's 8.75" axle assemblies.
Types of Sure-Grips Used By Chrysler
  • Between 1958 and 1969, Chrysler used the Dana Power-Lok design, which used clutches to provide the differential locking action.
  • From 1969 forward, Chrysler used the Borg Warner Spin Resistant design which used a spring-preloaded cone friction arrangement for the locking action. This design was later sold to Auburn Gear, so it is now usually called the Auburn style. The Auburn design was used in all M-Body 8.25" differentials that were ordered with Sure-Grip.
How To Tell If You Have A Sure-Grip
  • Check the fender tag under the hood. If it has "A38" or "AHB" listed on the tag (depending on the year), your M-body was formerly a cop car . Cop car M bodies almost always had Sure-Grip rears. If your M-body is not a former cop car, you probably have an "open" type rear and not a Sure-Grip.
  • Pull the oil fill plug. If you can see springs inside the differential carrier, it's a Sure Grip.
  • To check manually:
    • Block the front wheels.
    • On level ground, jack the rear of the car up so that the rear wheels are off the ground.
    • Put the rear of your car up on jackstands (good ones), and make sure that your car is stable.
    • Place the gear selecter in "N" for neutral.
    • Disengage the parking brake.
    • Turn one wheel and observe the other wheel.
    • If you have a Sure Grip, turning one wheel will turn the other wheel in the SAME direction.
    • If you do not have a Sure-Grip, the other wheel will turn in the OPPOSITE direction.
How To Tell What Gear Ratio You Have
To properly determine your gear ratio, you will first need to know if you have a Sure-Grip style rear or an "open" type rear.
  • Sure-Grip Differential - Both rear tires must be off the ground if you have a Sure-Grip.
    • Chalk mark a spot on the diffential housing.
    • Chalk mark the driveshaft and align it with the mark on the housing.
    • Chalk mark a wheel where it will be visible.
    • TURN THE REAR WHEEL.
    • Count the number of times the driveshaft spins for ONE revolution of the rear wheel.
    • This number (including fractions of turns) is the gear ratio.
  • Open-Style Differential - You MUST leave one rear tire on the ground if you have an open differential.
    • On level ground, jack one side of the car so that only one rear tire is off the ground.
    • Support the raised side on a jackstand (a good one), and make sure that your car is stable.
    • Count the number of times the driveshaft spins for every TWO revolutions of the wheel.
Sources:« Last Edit: January 08, 2008, 16:05:59 by Reggie » Logged
Old Jul 27, 2021 | 04:03 PM
arnolds 69 dart's Avatar
my 69 dart has 323s im thinking on 355s is it a good choise dart is 340 4 speed
Old Jul 27, 2021 | 07:47 PM
Archer's Avatar
arnold -
I wouldn't. The difference is marginal, and if you're going through the expense of a gear change, IMHO, the difference won't matter all that much.
(You can use any of the on-line diff/rpm/mph calculators to see the difference.)
If you wanted the car for a more specific purpose, then a higher (numerical) gear ratio might be in order.
BTW - I've run 3.23s in my Charger for decades, and recently switched to 3.90s.
Mileage and highway RPM aside, it really woke up the car.
So think about how you'll be using the car.
Old Jul 28, 2021 | 09:39 AM
i'm with archer. go deeper if youre gonna swap, you wont even notice that change.
MReeves
Stock Eliminator
Dec 12, 2011 10:26 AM
v6spitfire
Feb 18, 2009 10:54 PM
darkcrow
Oct 4, 2008 01:59 PM
debby440
Jun 18, 2008 11:55 PM
transman037
Jan 20, 2008 09:56 AM
