440 engine parts worth/interchangeability
Old 10-14-2008 | 01:54 PM
Commando's Avatar
I am trying to determine if I should sell the rest of the stuff I took off the 1977 440 engine I am still rebuilding like: the intake, distributor, carb, lean burn. Will those fit on my 1977 400 engine if I ever decide to restore it?
Also I assume I can sell the cylinder heads, pistons, cam & parts (lifters, rods, and timing chain), and the cast crank as I will have no use for them.
I already sold the valve covers (now thinking I should have checked to see if they'd fit on the 400), and the exhaust manifolds.
Last edited by Commando; 10-14-2008 at 02:01 PM. Reason: Forgot years on engines, might help
Old 10-14-2008 | 04:57 PM
plymouthrr1985's Avatar
Im pretty sure your intake and distributor wont fit. The 440 is a rb engine (raised block) while the 400 is a b engine. They have a different deck height so some parts wont interchange.
Old 10-14-2008 | 08:42 PM
Commando's Avatar
I didn't think so, but I am nowhere near any of the parts to visual compare, and some sites say there is some interchangeability.
Now that I have a confirmation on the intake, and distributor. Will the converted distributor on the 400 work with the lean burn carb?
hemiowner
01-31-2012 05:35 PM
pjjaramillo
09-18-2011 08:07 AM
sgnrulz
06-22-2011 09:03 PM
Kramer
10-27-2009 07:02 AM
Torontotony
10-05-2009 08:08 PM
