67 Belvedere 318 motor Sluggish after warmup.
Old Feb 20, 2010 | 11:54 PM
s13saru's Avatar
Junior Member
Okay guys. Finally got the 318 to idle decent and figured out the auto kickdown and got it dialed or so i thought. I went to start the Belvedere today and let it warm up for about ten minutes. Drove it around the block and everything seemed to work just fine. I let it idle for another 15 or 20 minutes in the driveway and took it for another spin around the block. After it REALLY warmed up the car seemed REALLY sluggish and seemed to struggle until about 3000 rpm and then it would smooth out?? I've got new points, distributor cap, rotor, and plugs. No vacuum leaks in the carb either. When I give the carb some throttle by manually pushing the throttle pin the motor seems to struggle and smoothes out at higher rpm? What could it be and where do I start? It was such a drastic difference between the first ride around the block from the second and I'm hoping it's not time for a rebuild just yet?
Old Feb 21, 2010 | 12:04 AM
theomahamoparguy's Avatar
how did you set the points? did you use a dwell meter?
Old Feb 21, 2010 | 12:14 AM
s13saru's Avatar
Junior Member
I didn't use a dwell meter to set the points. Just preset the gap by using a feeler gauge??? Could this be my problem? Thanks
Old Feb 21, 2010 | 12:21 AM
yes, I always used a dwell meter on my old points equipped cars. I think i set the points on my 318 to 32 degrees dwell. Points that are set too narrow act like you are describing. Plugs need to be gapped correctly too. Use the 67 specs.
I geuss these will be something I would start to look at first. (cause they're easy)' BTW, I had a 67 Belv. with points and 318.
Old Feb 21, 2010 | 12:24 AM
s13saru's Avatar
Junior Member
I'll check it out tomorrow and let you know how things go. Thanks for the great advice. I'm really leaning towards the electronic ignition as I'm not a big fan of these points. Oh well-I'm loving every minute wrenching on the Belvedere! They're great cars.
Old Feb 21, 2010 | 12:27 AM
I agree, my Belvedere was the best car I ever owned. And I've had a bunch of 'em.
Electronic ignition would be good also.
Old Feb 21, 2010 | 07:13 AM
have you also checked the timing?
Old Feb 21, 2010 | 09:47 AM
s13saru's Avatar
Junior Member
I set timing to 10 degrees BTDC. I'm heading out to set the points right now. Will let you know how it goes. Thanks
Old Feb 21, 2010 | 04:08 PM
s13saru's Avatar
Junior Member
Well... it was the points! Set the gap again and used a dwell meter this time... Idled better than ever and runs like a new car! My next purchase is going to be a Mopar electronic ignition most definitely. Thanks for everyone's help...It feels great to have the Belvedere on the road running like a champ!
GrandpasDream
Apr 17, 2014 09:43 AM
vanderlejm
Aug 18, 2012 06:49 AM
edemestihas
Dec 29, 2011 07:41 AM
Johnny2stroke
Dec 27, 2011 04:42 PM
belvedere1965
Jul 2, 2009 08:58 AM
