'68 Charger Starting issue.
Old Aug 5, 2010 | 05:55 AM
MNMOPAR's Avatar
This summer when I got the charger out of storage it had developed a new issue. The car will crank all day long and not start till you let the key back to the run position, then the engine fires up. I have been living with it all summer because I only drive the car a couple times every other weekend or a evenings once in a while if it is nice out. I am wrapping up another project this week and would like to fix this issue. Anyone have any ideas? I plan on hitting the electrical diagrams one evening this weekend.
Old Aug 5, 2010 | 09:59 AM
sweeperking's Avatar
Any one else thinking ballast resistor
Old Aug 5, 2010 | 12:29 PM
rdrunner1974's Avatar
Start relay
Not the ballast resister. It is bypassed in start to apply full voltage to coli during start and when in run the voltage is reduced through the ballast.
I would guess the start relay is not giving the full voltage when the key is in the start position and the relay energised.
You can test the ballast by putting a jumper wire on it. Is this a 2 prong or 4 prong ballast?
I can post wiring diagrams for both if you need them.
Old Aug 5, 2010 | 02:58 PM
blue 68 gts's Avatar
Ignition switch...
Old Aug 5, 2010 | 03:38 PM
short of going into a detailed explanation, I still bet its the ballast
Old Aug 6, 2010 | 08:05 AM
MNMOPAR's Avatar
It is a two prong ballast resistor. I will test some this weekend and let ya know the results.
Old Aug 7, 2010 | 07:34 PM
MNMOPAR's Avatar
Got it figured out. The wiring block at the firewall has some loose connections and corrosion. Fixed a couple wires and tweaked a couple plugs and she fires right up.
Old Aug 7, 2010 | 09:17 PM
Hm. Bulkhead connector didn't even come to mind..
I was thinking the ignition switch because it sounded like it was "catching" when you let the key fall back and would fire up then.
Glad to hear its running good.
19newport72
Mar 27, 2024 06:44 PM
markmets415
Jun 1, 2013 11:21 AM
rookie440
Jun 27, 2011 08:09 PM
DUST360
Sep 22, 2008 09:44 PM
speedtriple
May 30, 2008 03:45 AM
