68 Coronet Superbee: Neutral Safety Switch and Connector?
Old 04-05-2020 | 09:55 AM
TCCook1's Avatar
Question 68 Coronet Superbee: Neutral Safety Switch and Connector?
Hi, and apologies if this has been covered, I've tried to search/read every reference, no luck:
1968 Coronet (real) Superbee, 383 with 727 auto (column)
Replacing both NSS and the 3 wire connector, but the only NSS I find anywhere is the flat 3 prong switch in my attached picture, for which I cannot find the 3 wire connector/plug that fits over the switch. The connector picture attached shows the only ones I find anywhere, with the partial "half moon" ledge inside the connector which obviously doesn't fit onto the flat pin base of the switch. I need the Connector that is deeper with no half-moon-ledge-thing inside with the wires coming straight out the back instead of off the L shaped side. Hope that makes some sense, as I can't find any pictures even of the "straight out the back" connector.
Thanks in advance, need to get this thing done so I can find it a new home.
TCC
half moon raised ledge beneath connectors won't let this go onto NSS
Flat/even base of new NSS
Old 04-06-2020 | 04:00 PM
Thats the rite switch and connector....
Old 04-07-2020 | 08:02 AM
TCCook1's Avatar
Hey, thanks much for the response. But it physically just doesn't go over the pins. Hard to see in the pic, but the connector has that internal "ledge" next to the pin sockets, but the switch is completely flat, so no indentation to allow the connector to go over the pins. That raised half moon ledge hits the black pin base and keeps the pins from reaching the sockets. I've read that there were two types of 3 pin connectors used in '68, but can't find the other one without the ledge anywhere. May just end up trying to cut/trim out the ledge part...
Old 04-07-2020 | 12:17 PM
Have a look at these.... Looks like one has a short shoulder and the other is the one you have a photo of in you hand?
https://www.napaonline.com/en/search...=nol-veh-conds
And The Connector....
https://www.napaonline.com/en/p/ECHE...itch+connector
Old 04-08-2020 | 09:56 AM
TCCook1's Avatar
Thanks much for the napa link - the "shorter one" might work, just need to ask them for a picture of the whole pin area - of course they just have the one angled pic, with 3 full pics of the one I already have.
Much appreciated
MapleMan
08-19-2015 09:27 AM
Jgriggs29
04-19-2015 09:46 AM
dsikkema
08-30-2013 09:52 AM
willysman69
11-11-2012 08:08 AM
hemihead
03-18-2008 04:23 PM
