71 charger 440
71 charger 440
I'm new to mopars, I have a 71 charger with a 400 that's runnin pretty rough has a low end knock and lifters are rattling, I'm thinking about pulling the 400 and putting a 440 in, the 440 is out of a rv so from what I read it has crappy heads. Will the 400 heads fit in the 440? is it worth the effort to swap it or should I just keep and fix the 400
You got oil in the pan?
The only time I've had a big block with no oil presser was when the presser relief valve stuck open in the oil pump, broken spring behind the piston.
400 - or - 440
BuckNeccid
01-12-2012 04:38 AM
