71 charger 440
Old Sep 10, 2015 | 07:47 PM
1stcharger's Avatar
71 charger 440
I'm new to mopars, I have a 71 charger with a 400 that's runnin pretty rough has a low end knock and lifters are rattling, I'm thinking about pulling the 400 and putting a 440 in, the 440 is out of a rv so from what I read it has crappy heads. Will the 400 heads fit in the 440? is it worth the effort to swap it or should I just keep and fix the 400
Old Sep 10, 2015 | 08:13 PM
You got oil in the pan?
Old Sep 10, 2015 | 11:28 PM
1stcharger's Avatar
Yea just put the pan back on after checking the bearings and a new oil pump becuase I'm getting no oil pressure, nothin to the sending unit, and nothing splashing on top of the motor
Old Sep 11, 2015 | 08:34 AM
NCC1968's Avatar
Is the shaft and pump actually turning?
Old Sep 11, 2015 | 09:59 AM
1stcharger's Avatar
I took the cap off and spun the shaft from the pan and the rotor turned
Old Sep 11, 2015 | 10:00 AM
NCC1968's Avatar
You may have a bad pump.........it happens. You can take it off and spin it with a drill.......check 'er out.........
Old Sep 11, 2015 | 11:59 AM
The only time I've had a big block with no oil presser was when the presser relief valve stuck open in the oil pump, broken spring behind the piston.
Old Sep 11, 2015 | 12:08 PM
1stcharger's Avatar
I'm counting on it shouldn't be that it's a brand new high wolume oil punp
Old Sep 11, 2015 | 12:18 PM
NCC1968's Avatar
That can happen too. I've had some low b/c spring was crap.
Old Sep 12, 2015 | 07:39 AM
Magoo's Avatar
Smile 400 - or - 440
---- If the 440 is decent, low miles etc., I'd go with it. - Improve it over time, and your car will be worth more, come sale time. -- Good luck with whatever you choose.
Old Nov 28, 2015 | 10:39 AM
dgbcharger's Avatar
Stroker it
Pull the 400 and combine it with the 440 crank etc. etc. you'll have a whopper stroker motor.
BuckNeccid
Jan 12, 2012 04:38 AM
olebrowndodge
Feb 10, 2011 03:28 PM
68lover
Apr 20, 2010 07:23 PM
DartConvertible
Oct 8, 2009 11:59 AM
