73 satellite k members
Old May 11, 2010 | 05:38 PM
timmie124's Avatar
I'm going to swap my Plymouth 318 for a 360 and I've been told i need to change the k member, I've looked around trying to find a k member for a 360 but was not able to find anything for a b-body.
i was wondering what the part number is for a 360 k member or a conversion kit. If i need to use a conversion kit for a 318 k member i still need the part number because its cracked and split in more then one place
Old May 11, 2010 | 06:49 PM
1966sportfury's Avatar
A.K.A Bob Dodge
no there is no reason to pull the k member. even if you go big block there still no need to change the k frame.. and you say you have a cracked k frame? wow..all you need is the k frame from another small block
Old May 11, 2010 | 10:06 PM
timmie124's Avatar
the engine will still mount the same?or do i need a converter?
Old May 12, 2010 | 06:34 AM
A.K.A Bob Dodge
the engine will mount the same.. i believe the drivers side mount is slightly different. but cannot remember for sure... you will need a different tourque converter. i usually pull a 360 in favor of a 318.
Old May 12, 2010 | 07:19 AM
timmie124's Avatar
what kind of torque converter should i get. i just bought a new torque converter when i got my transmission rebuilt its a a904
Old May 12, 2010 | 02:08 PM
ryan's Avatar
i believe you could use the same torque converter but i believe that the 318 tq con has a neutral balance and the 360 has some weights on it. you could use the b&m flexplate that should eliminate the need for a new converter or ive heard but never done that you can get weights and template to make it work. i agree with 66sportfury there's no reason for a different k member except to fix yours
Old May 12, 2010 | 02:58 PM
koondawg_74 roadrunner's Avatar
Yeah you dont need to change the k member..one of my friends with a 73 rr put a 400 big block in it and didn't have to change it
Old May 12, 2010 | 05:11 PM
A.K.A Bob Dodge
yep you can add weight but it need to b in the right location.
1 Bad Mirada
Jan 5, 2010 03:19 AM
Polaradude
Oct 10, 2009 06:22 AM
Polaradude
Sep 22, 2009 07:22 AM
joedirt77
Nov 13, 2006 08:21 PM
