74 roadrunner small block to big block conversion
Old May 11, 2010 | 09:31 AM
74bbroadrunner's Avatar
Exclamation 74 roadrunner small block to big block conversion
I'm taking out the 318 and putting in a 440 in my 74 roadrunner would the 699 oil pan with the motor clear the k frame. I'm planning on putting in schumacker motor mounts. Also will the stock ignition from the 318 work for now until I can afford MSD.
Old May 11, 2010 | 04:50 PM
1966sportfury's Avatar
A.K.A Bob Dodge
stock ignition meaning the electronics...yes not the dizzy tho. as far as the pan i couldnt tell you. measure. it could depends what it out of.
Old May 11, 2010 | 09:22 PM
The electronics is what i was wondering about thanks, i read that if u have a mid sump on ur pan with the motor mounts you'd be fine i was just wondering.
Old May 12, 2010 | 03:31 AM
rdrunner1974's Avatar
oil pan
200-1123 fits ALL 66-74 B bodies and All big blocks, check it out
http://store.440source.com/Oil-Pans/products/54/
Old Mar 13, 2012 | 08:19 PM
cuda guy's Avatar
do u guys build hot rods or ****** on them wtf get a clue
pipdog69
Mar 13, 2012 11:01 PM
T.Atkeson
Jan 9, 2012 11:27 PM
68satellite
May 23, 2009 05:33 AM
Brent1960
May 17, 2009 04:25 PM
mahd
Apr 2, 2009 09:05 AM
