Aftermarket a/c for '69 Coronet 440
on
I'm looking for an aftermarket a/c for my 69 hardtop 440. It has a 318 engine. I looked on Vintage Air and I don't see one they sell for me. Is there another that will work, or should I look somewhere else?
Thanks.
Michael
Thanks.
Michael
Is it an air cond car ? Call them on the phone and ask for their advise.. The 318 motor should be easy to find brackets for if needed, You would need something to mount under the dash Like they did on the early Dusters
We did some old pickups back in the day and were able to use the oem number for AC parts if the truck "could" have come with AC an option and then took those numbers to track all the vehicles in the lineup that used the same OE numbers.
Example: F100 had the same AC unit as the Bronco and same interior controller and vacuum pump doors as the E100 vans. With the list of "same" donors we got everything out of the bone yard for short money.
It doesn't answer your question exactly but hopefully it will point you in the right direction if your ride could have had the option. In my experience almost all the parts are multiple use applications.
http://www.classicautoair.com/Mopar_..._Mopar_AC.html
Never heard of these guys but I found them for you.
http://www.oldairproducts.com/catalo...120132033.html
hckrphil
07-27-2014 10:59 AM
Demented
07-23-2009 03:59 PM
