blown motor :(
I was driving down the freeway, went to go pass someone, kicked it into second and all of a sudden the inside fills with smoke. I lost about a quart of oil. And now there's a really bad knock. It barely wants to run.
Don't run it anymore there could be numerous things that happened. I would yank the motor and disasemble it and find out what really happened.
Agree dont run it anymore, there is 1 bright spot tho... All the internals sounds like they are still internal.... Pull it drain the pan and pull the oil pan... Figure what part(s) are wanting out then make the determination of how to proceed.
![Yikes](https://moparforums.com/forums/images/smilies/yikes.gif)
Sounds ok ?? What is the oil pressure ?? I would at least drop the pan and inspect the bearings
I had a 360 street car and I sucked the pan dry and lost oil pressure at the strip. Motor sounded fine afterwards BUT the oil pressure was much lower. I ignored it and a while later the crank broke. I think with the bearing clearances the crank was flexing too much until it broke
Depends on how far you want to go with the rebuild, probably want to get the blocked check out after you tear it down before doing anything to it. Depending how far you go with the rebuild expect 2-3 grand
I was in Woodland, CA (by Sacramento) last weekend and I know where there is a complete fresh 318 Poly, a complete 360 with a thermoquad with the torqueflite still attached and a complete 400/2bbl without a carb but, with a 727 behind it.
I don't know what the guy wants for any of them but, they're not in pieces....
maca
12-22-2013 10:58 PM
