Carb
edelbrock does NOT know how to jet a carb. 1. hint change only jets. or rods at a time if you change both you cant guess what the change was. 2. hint change jets and rod to more like the size of OEM carter carbs. 3. if the jet does not come out easy dont force, that will strip the jet out. 4. hint there is a trick to get difficult jets out. take it all apart, get a small torch on the jet, when the color of the flame changes hit it with water. let it cool should work. i have done this only once, but it did work.
