carburetion issues.
Old Mar 23, 2012 | 05:56 PM
daraj315's Avatar
carburetion issues.
so my car went from sitting for 10 years and maybe being driven once a year to me driving it everyday and as expected things are falling apart. it has a carter 2 barrel and today it started acting up. it won't idle when i stop but then it will level out after a few seconds and when i gt on it it cuts out really bad. i adjusted the timing and the space between the points but that fixed nothing. any ideas?
Old Mar 23, 2012 | 06:49 PM
Try running the engine at fast idle 2500 and operate the choke a few times while keeping the idle fast. Check fuel flow! Check the ign timing and the timing advance. Check the carb - Remove the mixture screws and spray carb cleaner in the recess. Check the Accelerator pump and float level..
Still not working ?? Soak the carb in cleaner & rebuild it..
Old Mar 24, 2012 | 08:31 AM
Ten years is a long time for a carb, especially one that "has been sitting." I'd suggest the carb is simply getting gunked up inside. Find the carb no. and get yourself a carb kit, and clean it out.
What year model? Do you have a factory shop manual?
Old Mar 24, 2012 | 12:21 PM
daraj315's Avatar
Well I figured out the problem. Plain and simple it needs to be rebuilt. The accelerator pump is shot, the gaskets are rotted, and it's full of gunk. And it's a 69, I don't have a manual though.
Old Mar 24, 2012 | 08:45 PM
You can download a few manuals here:
http://www.forabodiesonly.com/mopar/...al%2C+download
bobby68x
Mar 13, 2008 12:04 PM
66coronetgirlie
Feb 25, 2008 05:40 AM
ppkaprince98
Feb 5, 2008 12:07 AM
P0STER0CH1LD
Jan 21, 2008 12:59 PM
bgreene30
Nov 20, 2007 12:49 PM
