ecu trouble
Old May 9, 2013 | 06:35 PM
66belvkm's Avatar
ecu trouble
Had to replace my ecu on 66 belv 440,autozone also regulator spiked to 16 volts so replaced also. got 12 with key on and 14.50-15 running is this normal?
Old May 16, 2013 | 05:06 PM
moe7404's Avatar
be sure that the ECU and the voltage reg, box is grounded to the frame. a good diagram of the ECU can be found at ALLPAR.
Old May 17, 2013 | 05:53 PM
66belvkm's Avatar
Thanks for the reply. Its about 14.8, with lights and radio on.I noticed when car warms up it drops to about14-14,3.ckd. and redid all grounds also cleaned and greased bulk head connector.
Old May 18, 2013 | 08:43 AM
Getting up around 14.5 and more is too high. Check both the "sense" line, which is same as the line powering the regulator, and the ground path
To do this, do the following.
1--You need to check for voltage drop in the supply path from the battery to the regulator IGN terminal. Turn the key to "run" with engine off. Stick one probe onto the battery positive post. Stick the other probe onto the "key" side of the ballast, or if inconvenient-----
you can also use the blue field wire on 70/ later systems, or directly to the regulator IGN terminal on 69/ earlier system.s
What you are measuring here is the direct voltage drop in the path----
battery --- fuse link -- bulkhead connector -- ammeter -- harness splice -- ignition switch connector -- through the switch -- back out the connector (on the ignition run dark blue) -- back out the bulkhead connector -- and to the ignition, regulator, etc
ANY point(s) in the above path can have bad connections and cause a drop
You are HOPING for a very low reading, the lower the better. If you read more than .3V (three tenths of one volt) you need to find out where you are losing voltage. The more voltage that your read, is ADDED to an otherwise proper regulator, IE if you have .5 (1/2) volt drop, and the regulator is at 14, then you will regulate at 14.5V
2-- Now check the ground path. This time, make two measurements, both with engine running, battery "normalized" Make the first test with all accessories off, and once again with lights, heater, etc turned on
Run the engine at a good fast idle to simulate "low" cruise, and put one probe of your meter on the battery negative post. Stab the other probe directly onto the regulator mount flange, and be sure to stab through any rust, paint, etc. As earlier, you are hoping for a very low reading, the lower the better. More than about .2V (two tenths of a volt) means you need to improve grounding. The regulator MUST "see" the same point as the battery negative terminal.
Old May 18, 2013 | 06:40 PM
66belvkm's Avatar
Thanks for the info going to get into it tomorrow.
Old Jun 29, 2013 | 06:41 PM
66belvkm's Avatar
ecu/wire problem
Just want to thank you all for your response on my trouble shooting.Found lots of bad wires,replace and back cruising if it ever stops raining out.
Old Jun 29, 2013 | 07:04 PM
Very good
dbossev
Apr 3, 2015 09:28 AM
felipec2106
Dec 4, 2014 03:09 PM
RacerHog
Nov 16, 2013 10:51 AM
440GTXguy
Apr 20, 2013 10:14 PM
dsmtuned
Jun 3, 2009 07:06 AM
