Engine offset??
Old Feb 24, 2008 | 09:25 AM
64fury's Avatar
Engine offset??
Is it an optical illusion or is the engine (383) on my 64' Plymouth Sport Fury offset a few inch's to the right in order to clear the stearing box? Or do I have a problem with my engine mounts?
Old Feb 24, 2008 | 11:57 AM
It's been a long long time since I've worked on my 64, by my recollection is the same as what you "see." If you had a mount problem, the engine would probably be moving around under torque and causing other problems, like shift linkage binding, noise and banging, etc.
CadVetteStang
Aug 29, 2009 02:02 PM
rockstar
Nov 19, 2008 04:13 PM
rockstar
Nov 19, 2008 04:07 PM
djsyvrud
Nov 11, 2008 05:33 PM
deadkelly
Oct 17, 2008 12:36 PM
