headliner install ?
push down and back hard on the seat. then it should pop up. or there could be bolts hust under the carpet below the seat, the backrest will have two bolts revealed once the seat is removed, then pull up
on the liner. start from back, theres two wire hook that attach to the back bow, hook them into the slots above the rear window, then left to right and forward, stretch the liner and hook it on the serrated edges along the roof rail, youll see what i mean when yo start then when you get to the front do the middle first then work your way out both sides, pulling the edges over the serated lip. youll have excess mat. hangimng over you trim.
