Help with Charging issue
Hi everyone,
Today I started up the RR to see the ammeter discharging and my voltmeter only reading about 11.8 volts. Battery reads about 12 volts between the terminals when the car is running. As soon as I pull the negative cable the car dies. I am measuring about 20 volts on the output of the alternator itself (which I bought brand new this summer along with a brand new voltage regulator) and I also measured 20V on the connector going into the firewall. I pulled the voltage regulator and measured 12 volts DC (with the key in the on position) between both pins and ground per the instructions of the troubleshooting section in the Mopar service manual. Also, I changed the VR and no luck either.
Any ideas on where to look next???
thanks,
thanks,
Guest
Posts: n/a
i guess i need to ask-what year mopar are we discussing? and if you are pulling battery cables while the car is running with solid state regulators-you run a chance of frying regulators.
it's a '70 Roadrunner. I put a new alternator and voltage regulator in the car this summer and things have been fine until today. Now, I get about 12V on the voltmeter when running. Normally I would see about 14.5V across the battery with the car running. Also the ammeter is visually discharging. It's never done that until today. No more pulling of the cables ....I promise
depends on if you have the original style regulator (electro mechanical). If you do have it, this was designed to work with a alternator with only one field terminal. As stated, you CAN use the dual field alt IF you ground one of the field terminals. Dont matter which one. Of course the newer style electronic regulators require the use of the dual field alt. Is that a misprint of "20 volts going into the firewall"?
Update: Pulled bulkhead connector apartbased on article I read here: http://www.madelectrical.com/electricaltech/amp-gauges.shtml
and it looks like I am a victim of this problem. Does anyone have any good details on how to remove the dash? I would like to re-wire according to the article but having a tough time trying to get the dash out. Any help would be greatly appreciated.
thanks,
--mike
thanks,
--mike
