Help with fender tag decoding, roadrunner ´68
Old Aug 16, 2012 | 10:25 AM
Danne_S's Avatar
Need som help with fender/vin tag decoding, roadrunner ´68
Hi!
I have some questions regarding a fender tag on a roadrunner im thinking of buying...
The problem is on the second line there is a big Z, and that make me really confused.
What does that mean?
Would be really thankfull if someone here could help me and decode this!
/Daniel
Old Aug 17, 2012 | 07:32 AM
Danne_S's Avatar
Isn´t there anyone who can help me ?
Old Aug 17, 2012 | 10:44 AM
mr340's Avatar
There is plenty of knowledge here, be patient and someone will surely have the answer to your question.
Old Sep 4, 2012 | 07:04 AM
Danne_S's Avatar
Doesn´t seem to ...
Old Sep 4, 2012 | 04:22 PM
Leem's Avatar
Hmmm, looking at the two different tags there? Are they off the same car, cause they don't look like they match. Am I wrong? I've had a couple of beers.
Marty
Old Sep 4, 2012 | 04:26 PM
Leem's Avatar
Also, the only reference to a Z seems to refer to a special order V8 on 70 to 74 models, which might apply to the left hand tag in the pics. Somebody correct me if I am wrong, but I am interpreting the left hand pic as a VIN from a 72.
Marty
Old Sep 4, 2012 | 05:12 PM
mr340's Avatar
The left pic (the fender tag) is absolutely not from a '70 or newer car. The body designation is the same on both the FT and the VIN RM21.
Here is what I was able to gather... The character under the "B" doesn't come up anywhere.
RM21 CAR: Plymouth RoadRunner 2 Door Pillar Coupe
62 ENGINE: 383cid 4-bbl HP V8
5 TRANSMISSION: 3-Speed Automatic
44 TIRES: F70x14 Red Side Wall, Steel Belted
709 BUILD DATE: July 09.
48 AXLE: 3.23 Rear Axle Ratio, Sure Grip
H4B INTERIOR: High Trim Grade, Vinyl Split Bench Seats. Light Blue Interior.
QQ1 PAINT: Monotone Bright Blue Metallic Paint.
U OTHER: Light Blue Metallic Upper Door Frame Color.
MOLDINGS:
25: Drip Rail Mouldings
47: 'B' Pillar Mouldings (for coupe)
ABC OPTIONS:
F0: Decor Package
R1: AM Radio
Z8: Performance Hood Treatment (Roadrunner/GTX)
abc OPTIONS:
NONE
Old Sep 4, 2012 | 06:16 PM
Leem's Avatar
OK, I can see now that the figure I had interpreted as a G is really a 6. But, now my question is...the two tags don't match...or am I missing something?
Marty (3 more beers)
Coronet1970RTguy
May 24, 2023 07:32 PM
rcknrolfender79
Mar 22, 2013 11:27 PM
Hoggy1
Aug 5, 2012 03:38 PM
MarkyMark12345
Mar 16, 2009 01:02 PM
piratemike
Sep 22, 2008 08:25 PM
