Help, Leak I cannot spot down
Guest
Posts: n/a
I had just filled my coolent level and drove the car after I noticed I had a puddle of Coolent on top of my water pump, I cleaned it up drove the car again and there was another puddle. I have no idea where its comming from Its not the hose but there is nothing elese up there. if someone knows what this can be please help
I assume you are referring to the hose going into the thermostat, there are two hoses on top of mine, a thermo sensor and a vacuum. If its not the hoses I would check the sensor, is it a drip from higher up, or running down the hose, also do you have a clamp on the hose?
