Hmm this isn't right.
Old May 28, 2010 | 08:20 PM
RROriginals's Avatar
Well this is the weird thing. On my Roadrunner, I tried starting it up, not even a sound, NOTHING, could the battery be THAT dead? Even the horn doesn't work, not one light turns on. The horn does work though, just wondering if the battery needs to be good.
Old May 28, 2010 | 10:57 PM
1966sportfury's Avatar
A.K.A Bob Dodge
more likley a bad connection on the battery post, or you left somthing on
Old May 29, 2010 | 07:10 AM
Archer's Avatar
rr -
Things like the lights and horn require very little voltage, sounds like something got disconnected. If not, do a voltage check across the terminals.
Old May 29, 2010 | 09:10 AM
samuelcosmo76's Avatar
Correct me if I'm wrong guys, but I remember my grandpa cleaning the battery terminals with seltzer water.
Old May 29, 2010 | 09:52 AM
sweeperking's Avatar
baking soda and water works also
Old May 29, 2010 | 10:48 AM
blue 68 gts's Avatar
Or if there is corrosion, just some hot water does the trick
Old May 29, 2010 | 08:49 PM
67gtxclone's Avatar
It sounds to me like the battery is completely dead. Most parts stores will do a free load test on it and check for an internal short. I would also suggest a battery post cleaner tool to get the junk off the posts and connectors to assure a solid connection.
Old May 29, 2010 | 10:10 PM
scotts74birds's Avatar
Best and cheapest.
Old May 30, 2010 | 07:48 AM
BuckNeccid's Avatar
Check the heavy red wire going thru the firewall bulkhead from the solenoid to the back of the fuse box. 71-4 b-bodies were bad for this connection to overheat, corrode, melt, pop loose, etc. Several times I've had to pop mine loose and clean it, and that was after I rewired the car when building it.
Old May 30, 2010 | 06:55 PM
timmie124's Avatar
could be your nuetral saftey switch if your trying to start your car. when i got a new battery and my car wouldn't even make a noise but some electronics would work, i switched everything out even the starter and nothing worked until i noticed a wire hanging next to the tranny
Old May 30, 2010 | 06:59 PM
It'll still start / run without the neutral safety switch hooked up. Without it hooked up, you'll just be able to start it in all gears
Old May 30, 2010 | 07:00 PM
Got a new battery, alternator, starter, lots of new parts today so it runs fine now
Old May 30, 2010 | 07:46 PM
The neutral switch is the ground for the starter relay. If simply unpluged the wire from the relay has to be grounded this will cause the car to start in all gear ranges (not a good idea though). If left simply unplugged the car wont start.
Old May 30, 2010 | 10:49 PM
A.K.A Bob Dodge
in one of my 3 diplomats it was completly missing. and it started up fine.. even in drive.....ooppps almost made a drive thru store once.
Old May 31, 2010 | 08:36 AM
You dont need a neutral switch to start your car all you need is a ground for your starter relay which is normaly done thru the neutral switch. The neutral switch (or lack there of) was bypssed in your diplomate. I did the same in my polara.
Old May 31, 2010 | 11:02 AM
A.K.A Bob Dodge
i didnt do it thats how i found out tho, was running late had to stop at the store. i shut it in drive .for somreason i just didnt put it in park,,went to start it up and it jump towards the plate glass of the store...that woulda sucked
Old May 31, 2010 | 07:03 PM
Talking
Yes It Would
Old Jun 2, 2010 | 07:45 PM
Mopar_71's Avatar
His car started... Yeah!!
That means it rolling again. With or without the NSS
Old Jun 3, 2010 | 07:12 AM
dodgenut7's Avatar
congrats on getting your car going its always nice to have another mopar on the road
Jeftam
Sep 13, 2011 05:58 PM
Crazy4Carz.Com
Sep 23, 2010 03:39 PM
RROriginals
May 27, 2010 09:09 AM
siliconcrunch
Dec 1, 2008 10:57 AM
