Mopar Forums (/forums/)
-   -   idle & brake problem (https://moparforums.com/forums/f10/idle-brake-problem-19809/)
jettley Oct 24, 2016 02:12 PM
I have a 70 RR when at idle it wants to stall and the brake don't really work, could this be a vacuum problem?
Coronet 500 Oct 24, 2016 05:06 PM
Welcome.
Yes. Take the hose off to the brake booster and plug, if idle should smooth out the booster is leaking. Make sure the hose is not leaking.
Archer Oct 25, 2016 06:00 AM
j -
You have a vacuum leak somewhere.
TVLynn Oct 25, 2016 10:21 AM
Or a big cam.. but like said check for vacuum leaks first
