ignition module confusion
Old Jun 2, 2010 | 06:33 PM
dwaynew's Avatar
Junior Member
Hi all. I'm new to the forums so bare with me. I have an issue on my 68 GTX. 440 with upgraded electronic ignition. My ignition module failed so I replaced it with a brand new mopar orange box and when it started everything seemed OK until about 2000 rpm. Then it was almost like there was a rev limiter and a miss. I then took this box off and installed a mopar chrome box from another car and everything seems good. Any thoughts on why this is happening.? I am ok running a chrome box but not sure why the orange box will not work.
Dwayne
Old Jun 2, 2010 | 07:07 PM
Barfly's Avatar
I know there is a difference in the ohm rating of the ballast resistor depending on which box you use..... I'll try to find the info....
Okay, here is the link where I saw the reference to the two different resistor ratings
about mid page they advertise
BALLAST RESISTORS
P2444641 1/4 ohm for chrome box and 4876733 coil 13.00
P5206436 1 ohm for orange box and 4876732 coil 8.50
Old Jun 3, 2010 | 09:15 AM
dwaynew's Avatar
Junior Member
Thanks for the info I will try this and see if this fixes her up. I am still confused though why the orange and chrome boxes would work on one car but not the other?? One is a stiock 440 and the other is a stroked 440??
dwayne
Old Jun 3, 2010 | 09:47 AM
Archer's Avatar
dwayne -
Barfly may be right about the resistor match, but a defective box is always a possibility.
If you want to find out for sure replace the orange box AND the resistor from the other car.
Old Jun 3, 2010 | 01:15 PM
Dwayne
exactly the same thing happened to me
i found out from mopar that the orange box's that they are selling have had some durability issues
also, my problem turned out to be a mis-wired harness
Old Jun 4, 2010 | 01:47 PM
dwaynew's Avatar
Junior Member
Thanks all for the ideas so far. I did discover that the ballast resistor from Napa is about 3 ohms where the mopar ones are either .25 or 1 ohm, any idea if this will make any difference??
Dwaynew
Old Jun 4, 2010 | 05:32 PM
i think it might
the ballast resistor must be matched to the box
Old Jun 5, 2010 | 02:58 AM
rdrunner1974's Avatar
resistance
The higher the resistance, the weaker the spark. Think of it like a dimmer switch, the more resistance you apply, the dimmer the light.
1974Goldduster
Mar 12, 2023 02:11 PM
moparcanblue
Oct 26, 2011 08:39 AM
stazja01
Aug 23, 2011 04:39 PM
tmackx
Aug 23, 2011 02:23 PM
GMdude
Jul 9, 2009 04:42 PM
