Manual Transmission
Manual Transmission
Hey,
I have recently bought a 1970 Charger and I got a 440 for it. I think they year of the engine is 74. I'll have to double check. Does anyone know someone with one for sale cheap ish, or a good company to get it through?
Thanks,
Jon
Thanks,
Jon
You need an 18 spline A833 "b" body trans if looking for stock. Is it equipped for a manual ?
Otherwise you need quite a few parts Floor pan hump, shifter, Clutch linkage, peddle assembly - might consider a hydrolic clutch set up, flywheel-- pay attention to the year of the motor as They are balanced different forged vs cast - need different flywheels. NOT going to be cheap ! Another option would be to adapt a Viper trans- even more expensive
