new 1973 roadrunner hood
Old Feb 24, 2009 | 06:19 AM
  #31
Commando's Avatar
Originally Posted by rr69half6bbl
I have a 6horse . 150 gal. tank for a scat blaster cabinet i bought. its big enough to hold 2 car rims. at ounce. I paid 500 for the comp. and 650 for the blast cabinet and vacume canister for it. it was sent to me ready to use minus the sand. youll need at least a 5 h.p. comp. w 150 lbs storage. to run this type of blaster.
Do you have any problems with it not feeding, I think that's the same one I have been using in the back of my friends shop. He's got 2 150 gal tanks hooked to it, so I don't think there is an issue with the air. When it works right I could do a manifold in probably 20 min, when it isn't it can take hours.
Old Feb 24, 2009 | 11:06 PM
  #32
rr69half6bbl's Avatar
commando, At times yes I do, what happens is if you dont have a dryer on your comp. the moisture gets into the nozzle, then causes the sand to harden, you have to take the blast nipple out and use a pick to get the hard chunks of sand out of the barrel then it works great again. and too if you dont sift the sand very often , you get all the chunks of goo from the parts in the sand intake and it plugs it up. If you start loosing pressure just hold the end of the gun against your gloved hand and tap the trigger a couple times, this will force the air backwards into the intake tube and clear it out.
Old Feb 25, 2009 | 05:28 AM
  #33
Commando's Avatar
I never pulled the nozzle off, that might be a good starting point, I do however have it unclamped into the gun so I can blow out the feed line every so often. Thanks.
Old Feb 25, 2009 | 11:09 PM
  #34
Glad to be of help your welcome.
hmiller79
Jun 1, 2019 09:30 PM
rcknrolfender79
Nov 24, 2009 10:17 PM
kittrellimport
Aug 30, 2009 05:35 PM
makemineduster
Oct 14, 2008 04:27 PM
smokinsrt
Jan 31, 2007 06:48 PM
