Pulling the tranny!!!???
Old Apr 9, 2010 | 11:25 AM
64fury's Avatar
Ok Guys!
How esay is it to pull a 727 Big block from the car without pulling the engine. All I have is a floor jack and jack stands, can it be done?
Second coverting from a 64' 727 to a 68', besides the shifter and kickdown linkage is everything else pretty much the same, I know the 64' has diffrent valve body eetc!
And how esay is it to rebuild a 68' 727?
Old Apr 9, 2010 | 07:28 PM
64fury's Avatar
Thanks Scott,
REad your reply then it vanished? The floor jack and jack stands are for the car while getting the tranny out, can it be done without pulling the engine as well. I have a budy with a snowmobile lift that I was going to hit up when the time comes.
Thinking Just pulling and rebuilding the 64' tranny, and not trying to convert a 68' unless a 440 is in front of it!
Old Apr 9, 2010 | 07:46 PM
scotts74birds's Avatar
Sorry, took another look at the MC lift, then worried that the frame wouldnt clear. Thats why I retracted till I had a better answer! I think I need a snowmobile lift now!
Old Apr 28, 2010 | 01:01 AM
ryan's Avatar
all i have ever used to pull a auto is a floor jack i use wood so i dont dent the pan if it can clear the exh. it cuts down on removal time about 2 hours
Old May 11, 2010 | 05:53 PM
timmie124's Avatar
your going to need to lift the car about 24 inches, put the jack stands on the diffs not the frame so you can increase the height. first take off the cars drive shaft. then undo the lines going to the tranny. and don't forget the shift cables and acceleration cable. next you will want to take out the starter. take the fly wheel cover off and unbolt the torque converter, you will need to turn the crank shaft to do this. next you might want to stick another floor jack to hold up the engine so it doesn't slant \ like that when you take it off. use a jack and piece of wood or a transmission cradle and put it under the pan. unbolt the bolts and screw to the engine. then the tail shaft bring the engine back towards the rear of the car remove the torque converter. the rest is a little bit tedious. but shouldn't take longer then 2 hours
they make transmission jack adapters if you are interested
http://www.harborfreight.com/floor-j...ter-39152.html
Old May 11, 2010 | 06:15 PM
Buffalojoe426's Avatar
Make sure you have somebody else around to help, or at least to make sure nothing happens. I almost crushed my best friend taking one out!
Old May 11, 2010 | 07:10 PM
Barfly's Avatar
I pulled one out of my 69 Coronet. Mister, that is one heavy transmission.
We also did it with a floor jack and wood blocks. More room under the car the better. But you have to consider your reach too, lying on your back or on a creeper.
Make sure you have Strong help, mark the cooling lines, don't cut them one patch them back together with hose
Old May 14, 2010 | 08:49 AM
64fury's Avatar
Thanks for the info guys, got side tracked and will be starting this in the next week or so, Have a matser rebuild kit to throw in this tranny once it's out, and will be picking up a tranny jack at princess Auto (canadas version of harbour freight) this weekend!
Will keep you posted
Skynyrd
May 20, 2015 04:27 AM
Kevin71
Jan 11, 2015 07:06 PM
Outsider
Nov 23, 2014 08:40 PM
Joseph McClure
Feb 15, 2014 01:37 AM
74Runneer
Mar 2, 2013 06:16 AM
