Shackles
Old Feb 27, 2011 | 08:16 AM
Leem's Avatar
Shackles
Hi all,
The 70 RR I got last summer has shackles on it. They are not original, that much I know, and one side is starting to bend. I know the car never came with this much lift from the factory. What I would like to know is did they come with shackles at all?
Marty
Old Feb 27, 2011 | 09:00 AM
Silverick's Avatar
What you have are 'extended shackles' to provide lift.
You could replace these with the standard length shackle.
Rick
Old Feb 27, 2011 | 10:52 AM
MercuryDon's Avatar
They will ruin the leaf springs. Get them off ASAP !
Old Feb 27, 2011 | 12:11 PM
Leem's Avatar
Yes, I plan on taking them off before spring when the car goes back on road. But what I need to know is what to replace them with. Did they even come with shackles, albeit, shorter ones. Or, did they come with no shckles? I need to know that so I can get it back to as original as I can.
Thanks,
Marty
Old Feb 27, 2011 | 02:13 PM
MercuryDon's Avatar
The stock ones are about 5" overal length and 3 1/2" center to center.
Old Feb 27, 2011 | 03:40 PM
Yes, the car came with shackles. They are very easy to change too, so it won't be a major job.
Old Feb 27, 2011 | 04:04 PM
Leem's Avatar
Thanks for the replies. I just wanted to confirm that they did indeed come with shackles, just not the monstrosities someone put on the car. Will only cost me a case of beer to get changed. My mechanic is a Mopar, and beer, nut.
Marty
Old Feb 28, 2011 | 03:26 AM
You need to have a shackle on a leaf spring in order for them to compress/extand properly. As the spring compresses/extends, the over all length changes. The only way for the leaf to act like this is the have a shackle on it. If it did not have a shackle, then the leafs would not compress/extend, the ride would be terrible and you could tear the spring hangers off the car or worse.
re-animate
Dec 23, 2013 09:44 PM
jdhyatt21
Jun 23, 2011 04:11 PM
