temp gauge 66 bel II 318
Old 03-09-2010 | 06:22 AM
belve2's Avatar
Junior Member
newbie here again and will probably be a PITA for a bit since I know very little about this car
I've searched this forum but need help with this:
How do you test a temp gauge? the needle does not move at all from cold. I would like to use the stock gauge and I'm going to try to replace the temp sending unit on the intake today if I can find a replacement. thanks
Old 03-09-2010 | 07:59 AM
rdrunner1974's Avatar
temp sender
Remove the wire from your sender and touch it to ground. With the ign. switch on, the gauge should peg out to HOT. If so, your sender is bad. Senders are inexpensive and easy to replace. Her is one.
http://www.autozone.com/autozone/cat...&parentId=52-0
Old 03-09-2010 | 08:20 AM
belve2's Avatar
Junior Member
thanks much rdrunner....I've been on Ford & Chevy forums for years but this forum responds the quickest....glad to be on board here....
67hemidart
05-21-2012 06:29 PM
Imfast101
04-02-2012 03:54 PM
Norskinder
10-15-2011 09:09 AM
sendust
08-24-2011 01:48 PM
cletis
Cuda Specific Discussion
06-01-2011 05:29 PM
