temp gauge 66 bel II 318
Old Mar 9, 2010 | 05:22 AM
belve2's Avatar
Junior Member
newbie here again and will probably be a PITA for a bit since I know very little about this car
I've searched this forum but need help with this:
How do you test a temp gauge? the needle does not move at all from cold. I would like to use the stock gauge and I'm going to try to replace the temp sending unit on the intake today if I can find a replacement. thanks
Old Mar 9, 2010 | 06:59 AM
rdrunner1974's Avatar
temp sender
Remove the wire from your sender and touch it to ground. With the ign. switch on, the gauge should peg out to HOT. If so, your sender is bad. Senders are inexpensive and easy to replace. Her is one.
http://www.autozone.com/autozone/cat...&parentId=52-0
Old Mar 9, 2010 | 07:20 AM
belve2's Avatar
Junior Member
thanks much rdrunner....I've been on Ford & Chevy forums for years but this forum responds the quickest....glad to be on board here....
67hemidart
May 21, 2012 05:29 PM
Imfast101
Apr 2, 2012 02:54 PM
Norskinder
Oct 15, 2011 08:09 AM
sendust
Aug 24, 2011 12:48 PM
cletis
Cuda Specific Discussion
Jun 1, 2011 04:29 PM
