Thrust Washers
Old Jan 2, 2010 | 03:29 PM
jar84203's Avatar
Member
Thrust Washers
I was interested in tightening the play in the differential of a 66 Coronet and was wondering if anyone knew where to get the side gear thrust washers in various sizes to do this? Or do they even exist? Thanks.
Old Jan 2, 2010 | 06:56 PM
theomahamoparguy's Avatar
rear end shims
the 8 3/4 doen not use side thrust washers for the ring gear. It has threaded adjusters. Some shims may be used for the pinion gear to set its depth. Randy's ring and pinion, www.ringpinion.com has everything you could need. It may be possible that your pinion nut has loosened. Usually the gears do not go out of adjustment, Gears may be toast.
Old Jan 2, 2010 | 08:07 PM
jar84203's Avatar
Member
I was actually hoping to tighten up the play between the side and spider gears.
69Bird
May 27, 2014 04:18 AM
68 Sat
Mar 3, 2011 06:48 PM
Duster_n00b
Sep 29, 2010 11:16 AM
68 Sat
Nov 7, 2009 07:14 PM
