Transmission question...
Guest
Posts: n/a
I have a 1973 Charger with a newly rebuilt 383 magnum.I dont know what the original motor was but I reckon it still has the original trans.It is a 3 speed automatic and it shifts really quick, 2nd gear about 20-30mph and 3rd gear about 30-40 mph and it just sounds like it is running at a high rpm at 55-65 mph(it really loud).I think it just needs different gear ratio,but my question is what would be a good choice.With the gear setting right now it seems like it doesn't have enough take off power to me,but Im not a mechanic by no means,so I dont know what I would need to change.
Many of your statements are pretty subjective. If you've never driven anything like this, you just haven't got anything to compare to.
First, you can't change transmission ratios, only the RPM at which the transmissions shifts. This is affected partly by the "kick down" linkage, as well as what goes on in the transmission valve, and it's possible that there's something plugged there, I'm no expert on auto's, but for now, assume that it's maybe a combo of you not being used to the car, and maybe the kickdown.
Next, RPM versus speed is affected by tire size (diameter) and the rear gear ratio. There may be a (greasy) tag on the rear, and maybe not. Otherwise, block the car, jack up one rear, and put the shifter in neutral. Watching the driveshaft, and counting, rotate ONE rear tire TWO turns while you count the drive shaft revolutions. If, for example, the shaft moves about 3 1/2 turns, you have a 3.55 rear. If it moves 3 and about 1/3 turn, you have a 3.23, and so on. If it moves just a little past 4 turns, you have a 4.11, and so on. You can actually calculate how fast you will go with what RPM by using this ratio and the tire size.
I would buy or borrow a tach, and see what your RPM actually IS at say, 60 mph
You say you don't have much "take off power" but yet you think it's pretty low geared, which are not consistant. A low geared rear would give you lots of launch power
You really can't do much until you find out what you are starting with.
Just to give you an example, my old '70RR with 3.54 rear went almost exactly 70 mph at 3000 RPM. This means that at 6K, it was doing 140mph or a little more due to "tire growth" at speed.
Dragpnflydf
05-02-2013 03:17 AM
64_Polara
03-21-2012 10:51 PM
hubcap
05-28-2008 06:24 PM
