Valve Lapping????
Old Jan 21, 2010 | 02:23 PM
Slice's Avatar
Valve Lapping????
Anyone have an opinion on valve lapping? I've heard some people say it is an outdated process and a waste of time. I'm cleaning up some eddie heads that are about 10 years old, but the valves look to be in good condition. I cleaned them up with brake clean and some steal wool. They look pretty good, but i would happily do the labor involved with lapping if it will benefit- though if it is a waste of time I won't bother.
Old Jan 21, 2010 | 03:32 PM
studruss's Avatar
i like to do it to make sure the valves are seating the right way. It dosnt take that long and better to find something now than at 8000rpm
Old Jan 21, 2010 | 03:55 PM
BuckNeccid's Avatar
If you don't want to pay to do the full valve job again, it's cheap insurance to make sure that the valves are seating all the way around, just don't take too much off them. Heck, if you have them off, they look good, and you have the time, lap em.
Old Jan 21, 2010 | 04:59 PM
Slice's Avatar
Thanks for the quick response, wife just came home with lapping compound so I'm on it!
Old Jan 28, 2010 | 08:47 PM
hempsteadauto's Avatar
Junior Member
i always hand build my heads, i worked in a shop for 30 yrs and stone grinded plenty of values, but if you want a perfect fit you hand lap them in, i use a electric drill with a piece of 5/16 hose to couple the drill bit to the drill stem and a screw driver end to hold presure on the value seat,push the value on and off its seat as you lap,go in both forward and reverse, when power lap them in. ck the padern a few times until you have a solid perfect seat, takes many hours.its worst it if you want a car that runs perfect.
Old Apr 25, 2011 | 07:38 PM
ddunk80's Avatar
On a large valve, it would be turned with a drill. On a small valve, by hand.
__________________________
AC Delco Power Seat Control Unit
Old Apr 26, 2011 | 12:26 PM
mostang's Avatar
i do em all by drill it gets the dimples out of the valves and seats
74Runneer
Oct 17, 2015 10:32 AM
Manoharvalves
Sep 15, 2011 10:53 PM
scotts74birds
Mar 30, 2011 08:06 PM
CAT-TECH
Jan 30, 2008 08:46 PM
bschubarg
Apr 10, 2007 07:08 AM
