What is correct TorqueFlite transmission fluid for 64 Ply Belvedere 318
Old Oct 12, 2014 | 09:21 AM
Dad-Par's Avatar
Just purchased this vehicle (all orig daily driver) and want to be sure I'm going to use correct fluid. Always remember 'Type A'. Is current replacement Dexron/Mercon (progressive upgrade from Dexron, Dex II, III, addition of Mercon etc) correct for today.
Old Oct 12, 2014 | 02:26 PM
pro-tech's Avatar
Yes, Dextron III is what they call for now it has better lubricating factors then the old fluid... Bill
Old Oct 12, 2014 | 04:29 PM
Rooty's Avatar
I just changed my fluid in my 727 and Dex/Merc was recommended by service guy
at Chrysler dealership. Evidently it foams less, lubricates the moving parts better
and provides firmer shifts to keep the bands from glazing prematurely. Really, I
don't think conventional fluids make much difference but to be on the safe side,
ask a tranny place what they recommend.
Old Oct 12, 2014 | 09:09 PM
There is NO Dextron III, Replacement ATF+4
Old Oct 13, 2014 | 08:59 AM
Transmission Fluid Info
Just an FYI.... Transmission Fluid info Sheet....
http://www.carquestprofessionals.com...%206.10.13.pdf
Old Oct 13, 2014 | 09:07 AM
moe7404's Avatar
in the late 60s early 70s we did use type-F in torqueflites. but today i would only use ATF+4. minor history note: i was working a Case MFG in Wichita KS and engineering came out and said that type F could be used in the hydraulic systems. worked good in cold weather. my dad bought a Case garden tractor in 1975, 446 , 2 cyl engine. hyd system was sluggish when plowing snow. switch to type F fixed the trouble. its still in the 446. but today i think i would run AFT+4
Old Oct 13, 2014 | 12:46 PM
Dad-Par's Avatar
Correct Trans Fluid
Thanks to all. Have bottle of Castrol DexonIII/Mercon in front of me as I type. However just an FYI, was on OReilly Auto website under Fluids
&Chemicals > Transmission > found 'Type A' trans fluid - 'Pure Guard' brand (?) avail as a non-stock item avail in 24 hr item. Go figure. Not sure I m ready to jump at that.
Old Oct 13, 2014 | 04:24 PM
Moe... you should have used AW68 in that system.. Not Kansas crude oil...lol
Old Oct 13, 2014 | 04:27 PM
Some of that I just don't trust.... Pro Line oil was one that said it covered everything, "I just slowly put it back on the shelf and backed away" I to went with the Castrol....lol
Old Oct 13, 2014 | 07:32 PM
pro-tech's Avatar
Wow good to know I had better pull all the Dextron III or if you prefer Dex/Merc. off the shelves at the AutoZone store I manage.. I don't want to be selling something that is a figment of my imagination......Bill
Old Oct 14, 2014 | 06:34 AM
I think it's fragment Bill......lol
Old Oct 14, 2014 | 03:06 PM
pro-tech's Avatar
No Bob it is figment... It means Something merely imagined...oke:...Bill
Old Oct 14, 2014 | 05:24 PM
moe7404's Avatar
its just an out dated history NOTE. i dont under stand why EVERY MFG that makes a NEW trans need a NEW fluid. the old one seamed to work fine.
Old Oct 15, 2014 | 05:46 AM
pro-tech's Avatar
X10 That's why and it sucks...And the smell gets worse too....Bill
Old Oct 15, 2014 | 06:20 AM
Money is the key.... Keeping us guessing...
Dad-Par
Dec 18, 2016 08:21 AM
Dad-Par
Oct 29, 2014 06:31 PM
Dad-Par
Oct 12, 2014 11:27 AM
Dad-Par
Oct 12, 2014 09:18 AM
hlfishman
Dec 19, 2012 07:41 AM
